​1.1. Using Ambari with Oracle
  1. On the Ambari Server host, install the appropriate JDBC.jar file.
    4. Copy the .jar file to the Java share directory. For example:
    5. Make sure the .jar file has the appropriate permissions. For example:
  2. Create a user for Ambari and grant that user appropriate permissions.
    # sqlplus sys/root as sysdba
    CREATE USER <AMBARIUSER> IDENTIFIED BY <AMBARIPASSWORD> default tablespace “USERS” temporary tablespace “TEMP”;
    QUIT;
    1. You must pre-load the Ambari database schema into your Oracle database using the schema script.
    2. Find the Ambari-DDL-Oracle-CREATE.sql file in the /var/lib/ambari-server/resources/ directory of the Ambari Server host after you have installed Ambari Server.
  4. When setting up the Ambari Server, select Advanced Database Configuration > Option [2] Oracle and respond to the prompts using the username/password credentials you created in step 2.
