​1. Using Non-Default Databases - Ambari
The following sections describe how to use Ambari with an existing database, other than the embedded PostgreSQL database instance that Ambari Server uses by default.
[Important]Important
Using the Microsoft SQL Server or SQL Anywhere database options are not supported.
For High Availability (HA) purposes, it is required that the relational database used with Ambari is also made highly available following best practices for the given database type.
