​3.2. Using Oozie with MySQL
    1. Install the connector.
      RHEL/CentOS/Oracle Linux
      SLES
      UBUNTU
      DEBIAN
      # mysql -u root -p
      CREATE USER ‘<OOZIEUSER>’@’%’ IDENTIFIED BY ‘<OOZIEPASSWORD>’;
      FLUSH PRIVILEGES;
  3. Create the Oozie database.
      # mysql -u root -p
      CREATE DATABASE <OOZIEDATABASE>
