​3.3. Using Oozie with PostgreSQL
    1. Install the connector.
      RHEL/CentOS/Oracle Linux
      yum install postgresql-jdbc
      SLES
      UBUNTU
      apt-get install -y postgresql-jdbc
      DEBIAN
    • Where <OOZIEUSER> is the Oozie user name, <OOZIEPASSWORD> is the Oozie user password and <OOZIEDATABASE> is the Oozie database name.
